Anyone have trouble opening electric hatch?
75% of the times I've tried to open the hatch hitting the yellow release button it pops, but is still latched. If I pull upwards and keep hitting the keyfob release I can get it.
This has been reduced now to about 25% of the time after spraying WD40 into the mechanism in the trunk but want to know if there's anything else an unskilled person like myself can do to fix this problem.
Here ya go:
http://www.installuniversity.com/ins...sity/index.htm
Go under install documents, there's a write up on how to fix it.
Ya just got to an auto parts place and by another spring prefreably the same size as what you have or just a liiittllleee bit shorter and have both springs on there, and spray a lil silcone lube in there just to be up to date and maintance, and dont be suprised if that thing didnt upper cut ur *** once you hit that hatch release button!!
Travis
Travis
I did the spring mod and it worked great for awhile. Problem is the extra tension eventually bent up the latch mechanism. I need to use my remote and pull up on it to get it to open now.
Well then take off the original go to the parts place, and match the tension with another spring just something of the equal tension, or just slightly under tensioned just for added support for the other spring(Factory)
I put a similar sized but much stronger spring on mine and when It was completed the hatch damn near jumped off the car. Go to a hardware store like home depot or similar with the spring and find one that is a higher tension.
Originally Posted by 2kta--89formula
Here ya go:
