Did a little turbo fabbing last night...
I started fabbing up a stock exhaust manifold kit. Unfortunately the A/C gets deleted, but here are some pics showing some layout. The turbo is a garrett T67 rated for 750 fwhp. Opinions, questions, and comments welcome. It will probably go up on ebay unless someone is interested in it:
Originally Posted by omaha stylee
man that looks close to the harmonic balancer.. but nice setup
Originally Posted by whynot
what about you abs? and where are you runnung your dp?
Originally Posted by Rocko71
Thats cool. I hadnt thought of turing the manifolds backwards... that saves alot on packaging, huh?
I prefer t be contacted via email for questions because i check that more.
jrbellas95z28@yahoo.com
If you can give info on the kit, and if it works well im sure you could have alot of DIY guys wanting to buy it from you.
LS1 guys do it all the time im sure this would work decent, STS works good with stock manifold. I know its a whole different kit but it should be the same concept?
