Will I need new injectors and a fuel pump?
I plan on spraying a 100 shot using a dry kit on my bird. As of right now she has 106K on the clock. The stock fuel system has seen every bit of those miles. So my question is, will or should I replace my injectors and fuel pump?
That depends on your money status. I think the injectors will be fine, but that is limited to what mods are on the car now and how maxed out your injecters are. If you got the money then I would throw a racetronix pump in as a added sense of saftey for the motor. You could throw a fuel pressue gauge on the car and see what pressure it has. Just my .02 though
