Generation III External Engine - GROUND WIRES ON THE ENGINE...installed LTs and need some help...PLEASE!
MICAH HERRON
04-07-2006, 07:18 AM
I installed some long tubes on the car and I know I had to disconnect some grounds to the block. Can anyone remember, is there two grounds on the driverside?
I thought there was, but I can't remember for a fact.
Thanks!
Jhankinson
04-07-2006, 07:25 AM
there is one ground strap that runs from the block...just in front of the drivers motor mount...it routes into the harness around where the alternator wiring is....then there is grounds on the backside of the drivers head. As far as I know...thats the only ones on that side of the engine. If someone else remember any more...please chime in.
Josh-
MICAH HERRON
04-07-2006, 07:49 AM
Josh-
Thanks, what about the passenger side, there is just the one correct?
Steve Burger
04-07-2006, 08:13 AM
One from the drivers head is for the O2 sensors. One from the drivers side of the block is for the Alternator. One from the passengers side of the block is for the battery and starter.
I added one from the Pass head to the firewall. It helped a lot.
MICAH HERRON
04-07-2006, 09:13 AM
I am pretty sure now that I forgot the black ground wire that goes with the metal ground wire to the block on the drivers side.
Micah
What did it help with :confused:
Steve Burger
04-07-2006, 10:24 AM
I had a bad hesitation when it was damp. All of the other drounds were OK but when I added one it cleaned everything up. May have just been my car. But for 2.00 it worked.
MICAH HERRON
04-07-2006, 05:28 PM
Found the problem...over looked a second ground wire on the driver side, the car is running strong now.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
