Need Help Now!!!
Need Help Now!!!
where do the yellow and grey wires go on the msd window switch? I need help fast i can't hook my saftey switch yet cause i need a fitting anyone have any ideas?
grey is normally closed, this wire provides ground source at on rpm, and completes the ground circuit at set off rpm, yellow is normally open this wire will give ground at on rpm and remove ground at off rpm.
It has been awhile since I wired mine up, and I was looking through my notes, which off course make no sense, but I know I used the same colored wire through out keeping colors the same, and I have yellow on the FPSS.
Can anyone confirm?
Can anyone confirm?
Well i just took the damn thing out, and sprayed in the converter a couple times. I need to get it working, and get the saftey switch in too. I think i am going to call msd tomorrow. Thanks for the help, but what you told is the same thing the instructions said, and i am wiring illiterate.
