car is having bad vibes
well here goes all info is current in sig for explaining purposes.
im having a bad vibration at 75 and above it gets worse with mph increase. also if i push in the clutch at that speed to shift the vibration will go nuts and i feel it in the clutch pedal. I can go 74 and lower and it's fine. also in in all gears around 30 i get a bucking sensation, very hard to describe car seems to be lurching. i had my car at flp couple weeks ago and they bled the clutch and adjusted the exhaust. that helped a little. I also have an aftermarket driveshaft that is balanced to 3000 rpms.
also in neutral it will vibrate while sitting still at 3k and above not to bad but its there. i was told by mcleod that there street twin is balanced so i just put it in.
Any help will be great sinc i have a 150 mph + car with a 75 mph limit due to it vibrating my a$$ all over the place
__________________
__________________
