383 power
Old 04-08-2006, 05:52 PM
WHITEBIRD's Avatar
Default 383 power
does anyone know about how much horsepower i should be getting out of my set-up. no tune yet. 383 with lt4 heads and cam pacesetter longtubes, ory and b&m shift kit. thanks guys.
Old 04-08-2006, 07:06 PM
94greencamaro's Avatar
Are the heads ported?
What are the camshaft specs?
Whats the compression ratio?
You need to give us a little more info.
Old 04-08-2006, 07:24 PM
WHITEBIRD's Avatar
hotcam kit. heads are not ported
Old 04-08-2006, 07:31 PM
WHITEBIRD's Avatar
the pistons are diamond 8.6 cc boost pistons if that helps any.
Old 04-08-2006, 08:01 PM
Id guess around 360 rwhp. Youd get A LOT more out of it with ported/better flowing heads. You have a do have cold air intake right? And what about a 58 mm throttle body?
Old 04-08-2006, 08:06 PM
WHITEBIRD's Avatar
moroso cia no throttle body yet. thanx for the reply.
Old 04-08-2006, 08:07 PM
Billy the Great's Avatar
I made 370rwhp/433rwtq on my 11:1 383 with stock lt1 heads and a hotcam through an A4
Old 04-08-2006, 08:11 PM
Thats pretty impressive for stock heads
Old 04-08-2006, 08:27 PM
WHITEBIRD's Avatar
trying to keep it mild want add a supercharger soon.
Old 04-08-2006, 08:30 PM
Thats cool. I went with a custom cam just barely bigger than the hotcam due to the fact that its my only car and i prefer to have my gas mileage in the double digits.
Old 04-08-2006, 08:40 PM
WHITEBIRD's Avatar
what 1/4 mile times do yo think i can pull on street tires?
Old 04-08-2006, 08:47 PM
Your going to have a pretty shitty 60 ft on street tires with the extra torque the 383 is going to put out. Defenately dont slam it off the line. Im going to say 12.9 on street tires and 12.5 on DRs.
Old 04-09-2006, 12:09 AM
lol thats an understatement
my best 60ft is 1.9 on nittos and even that only happened a few times. best 60 on street tires is a horendous 2.2 or something pathetic. My friends say i just have a fat foot. cant wait to see what it does on a slick with a proper 60 ft (low 1.5-high1.4), should know in a couple months
Old 04-09-2006, 08:38 AM
96capricemgr's Avatar
For the price of as cast LT4 heads you would have been better of porting the stockers, the HOT cam is not the right cam for later boost and is pretty mild for a stroker, and no tune is a HUGE MISTAKE.
The B&M "shift kit" might very well be the worst offered for the 4L60E so plan on buying a tranny soon unless you put a real kit in there like the Transgo.
Sounds like you should have come here BEFORE you started the project, if a vendor sees you mind is made up on the WRONG parts they will often sell them to you anyway because you would walk away happier than had they told you what you actually needed.
Old 04-09-2006, 10:54 AM
Smokinlt1's Avatar
Old 04-09-2006, 01:59 PM
WHITEBIRD's Avatar
what cam would help get the most out of a 383. i want a streetable cam
Old 04-10-2006, 08:43 AM
Camaroholic's Avatar
Honestly with 8.6:1 compression NA, it's going to be a bit sluggish no matter what. I think you'd be lucky to see 340 rwhp. If you already have the hot cam, stick with it until you get the blower. Then when you put the blower on, swap to a different cam and sell the hotcam. Keep in mind that compression is power, and most numbers you see thrown around here are with engines in the 10.5-11:1 range.
"If it were me", I'd look for something mid-230's duration intake, mid-240's duration exhaust, 114-116 LSA, after you get the blower.
You will need tuning no matter what.
Old 04-10-2006, 11:06 AM
WHITEBIRD's Avatar
everything i have in my sig is still laying around. nothing has been instaled yet so i am still open for any opinons. if there is something i have to change i would like to do it write the first time .all info is helpful.
Old 04-10-2006, 12:38 PM
YenkoST's Avatar
The LSA should be 114 for a blower, nos, or turbo. You will lose power for NA numbers at first but once you get the blower...you will gain it back. If this is your daily driver, I would suggest a cam without ported heads with 8 degrees of intake exhaust split duration difference for example....222/230 cam or something like that. 222/230 would be the cam I would choose but that's just me. It you want more radical then go bigger.
Old 04-10-2006, 07:08 PM
97blkz's Avatar
Weak cam and heads that dont flow well mean small power, I'd agree with 340'ish!
Quick Reply: 383 power
