Got my MegaSquirt ..Now a Few Questions.
Old 04-08-2006, 05:54 PM
383LT1S10's Avatar
Default Got my MegaSquirt ..Now a Few Questions.
So I just ordered my MegaSquirt MS1 FMU yesterday, along with the engine harness and tuning cable.
http://www.diyautotune.com/catalog/m...unit-p-34.html
I have a few questions. Does anyone else have this setup and running succesfully on their LT, and if so did you keep the Opti or did you go for a drilled intake with a distributer? I seem to get varying answers as to if the Opti pickup will trigger the ecm.
I went with the MS1 since it has more features at the moment with the MSNS-E firmware than the MS2V 3.0 has. (though that will change soon I suspect). I plan on using it for spark and fuel control for now.
I am curious, how hard was it to get it initially up and running? I'm fairly knowledgable in electronics and such so that side of it doesn't phase me. I am just curious if anyone has a base map file they could send me as a starting point. Thanks!
Old 04-08-2006, 06:36 PM
BeaversTA's Avatar
I'm planning to use the MSII this summer with the EDIS ign.
Old 04-08-2006, 10:53 PM
Nite_Hawk's Avatar
Why couldn't you use the Crank sensor, most of the other guys are doing this...it would be basically the same as EDIS
Old 04-08-2006, 11:54 PM
383LT1S10's Avatar
Because I am running a 94' LT that doesn't have a crank sensor. Sure I could swap crank triggers and front covers but it's no harder than using a drilled intake and ditching the opticrap.
Old 04-09-2006, 02:08 AM
Nite_Hawk's Avatar
True...cool none the less. I'm going to run the MS setup on a 4cy turbo car this fall when i'm done building the T/A.
Quick Reply: Got my MegaSquirt ..Now a Few Questions.
