LS6 Intake VS Non LS6?
Old 04-09-2006, 05:50 PM
then00b's Avatar
Default LS6 Intake VS Non LS6?
Hey I was wondering how much of a difference the LS6 intake actually makes over the non LS6... Anybody know?
Old 04-09-2006, 05:52 PM
LS144's Avatar
If you are speaking of the fast 90mm intake your talking a pretty big difference. But you are also talking a big difference in price also.
Old 04-09-2006, 05:58 PM
then00b's Avatar
I meant a stock F-body 1998-2000 VS a stock F-body 2001+
Sorry, guess I could have been more clear on that.
Old 04-09-2006, 06:02 PM
c0ncEpT's Avatar
The difference is in the upper RPMS, The LS6 flows a little bit better than the LS1
Old 04-09-2006, 06:04 PM
then00b's Avatar
Any idea of how much of a difference it actually makes? The LS6 intake is rated at 5 more HP than the LS1 by GM, but that is probably off....
Old 04-09-2006, 06:41 PM
Ace$nyper's Avatar
I've read its about 5WHP and 10-15 crank.
Old 04-10-2006, 04:57 AM
300bhp/ton's Avatar
On a stock car you'll only get a mild gain and most above 4500rpm. On a bolt on car or a cammed car there will be much more difference and an easy 20rwhp could be gained at PEAK with at noticable amount across the board.
HOWEVER - depending on what your plans are it may not be the most affective $/hp. If you are planning on a monster n/a heads & cam setup then you'd be better off spending the money on a TPIS 90mm LS6 or a FAST 90mm using a 90mm TB.
If you plan on FI then it makes less difference as you will still see massive numbers even with an LS1 intake. 450-500rwhp won't be a problem and will be getting close to the limits of the stock short block, transmission and rear end.
It's all about knowing you goals and expectations and mod accordingly.
If you plan on a turbo setup then you don't need:
-LT's
-ORY
-intake
-lid
-pulleys
To name a few. Sure you might be able to make a bit more power with some of them, but considering you could easily exceed the limits of the stock short block without them, there's a pretty good case to say save your money until you build a forged block and can maximise it's potential.
Old 04-11-2006, 12:15 AM
Hoss Ghoul's Avatar
Where are you located? If emissions provisions are a concern the SLP LS6 intake may be what you want since it keeps EGR and AIR pump provisions.
