What are "All Bolt ons"??
What are " All Bolt ons " ??
I have an Moroso CAI, 52MM Holley and SLP Loudmouth with Hooker Tips.
Like the Title says, what am I missing?
Are headers bolt ons?
a 52 MM throttle body bolts on, does that count?
Technically, almost every part of a car is attached via clips or bolts, but bolt on usually applies to;
natural* induction improvements (up to intake manifold, sometimes including)
exhaust (yes, starting with headers)
suspension (can also include chassis stuff like SFCs)
engine accessories (like the aforementioned UD pulley)
*Unless engine in question had an OEM forced induction device, then this definition would encompass upgrading something like a pulley.
"bolt-ons" are defined herein as anything that can be bolted to the motor leaving the shortblock, heads, and cam(s) untouched. So an intake is considered as a bolt-on. Ofcourse, bolting a blower or nitrous is "bolting" something on but your are changing the classification of the motor from N/A to FI. So the mass majority doesn't consider a power adder a bolt-on. -Mark
That's what she said...
Originally Posted by Toasty
FI doesn't count because while you may not be changing the internals, you are changing what goes ON inside there.
Blowers and turbos get knocked out by the "if they touch oil" rule.
Originally Posted by JDP
well on my rustang, i bolted on some 1.7 roller rockers, would that count? sure oil touched them but it was a simple mod
-Mark
