Purge into an exhaust pipe
Old 04-10-2006, 12:11 PM
Flyer's Avatar
Default Purge into an exhaust pipe
Thought?
Trying to think of a way to hide a purge.
Old 04-10-2006, 12:13 PM
TRYTHSS's Avatar
hiding it is one thing, covering up the noise is another. mine is Very loud, but maybe if you purge during a burnout it might help. I wonder how flammable it would be back their in the exhaust?
Old 04-10-2006, 12:14 PM
Flyer's Avatar
Thats a concern I had ... or if it would expand way to quick and open up a muffler.
Old 04-10-2006, 12:25 PM
rocketman442's Avatar
Try it and find out, just keep the extinguisher handy, just in case.
Old 04-10-2006, 12:27 PM
Anidote00's Avatar
Are you runnin a hand held button or a micro switch on the pedal? Most of the time I just purge mine through the motor in the burn out box, if you have hand held button. Most people will never even know!
Old 04-10-2006, 12:59 PM
GFORCE1320's Avatar
Just blow it out and show it ! Be proud of that gas, LOL..The crowd loves a good nitrous purge
Old 04-10-2006, 01:03 PM
Spenser309's Avatar
just purge into your interior............
Old 04-10-2006, 01:05 PM
Spenser309's Avatar
seriously though, if your gonna do it make sure its after the cat, otherwise when the fuel in the exhaust goes through the cat it will have enough oxygen to explode, my thoughts.
Old 04-10-2006, 01:10 PM
Gabriel's Avatar
Just run the line from the solenoid down into the engine bay so it purges underneath the car or into one of the fenders. You shouldn't be able to see it while doing a burnout, or at all for that matter.
Old 04-10-2006, 01:30 PM
8 second mod
Noyzee's Avatar
i dont even run a line off my purge. i just let it go under the hood, you can hear it, but the burnout idea would work!!
i might run lines this year, just so i can be sure both purge's work
Old 04-10-2006, 01:38 PM
TRMIN8R's Avatar
I don't even use a purge anymore. Just for show IMO. I just "purge" the nitrous and fuel at the same time through the motor.
Old 04-10-2006, 01:47 PM
8 second mod
Noyzee's Avatar
purge is huge when you run big shots!!!!
it has a big effect on your tune up.
to much psi, and boom, to low, and you wash down the motor.
purge makes a big deal.
i dont purge outside just for that reason, and i got rid of my master blaster and went with a basic one just so it was hard to hear. but on big wet shots, its good for tunning, and consistancy
Old 04-10-2006, 02:08 PM
Flyer's Avatar
Should the fuel be purged as well???
Old 04-10-2006, 02:22 PM
8 second mod
Noyzee's Avatar
i dont purge it, but some people do. the real big dogs do it. it puges back into the fuel cell.
Old 04-10-2006, 02:36 PM
87Lt1Monte's Avatar
Last time i checked on the side of my bottle its a non flammable gas? how could it "catch fire" .. I would really like to know.
Old 04-10-2006, 02:53 PM
8 second mod
Noyzee's Avatar
it wont catch fire, but i guess in a rare case, it could combust some how once it hit the muffler or what ever.
Old 04-10-2006, 02:54 PM
Tenured Member
Outlaw Motorsports's Avatar
Unburnt fuel and the heat from the Exhaust
Just do the motor purge in the burnout box. When you do your burnout and your just about ready to get off the brakes and start rolling foward for the "Grab" feeling. Thats when you can hit it for a second.
Old 04-10-2006, 04:00 PM
Spenser309's Avatar
this would be a great way to make 6ft flamthrower system a 12ft flamethrower system.
Old 04-10-2006, 04:54 PM
Phoenix 5.7's Avatar
i have seen setups into the rear wheel wells, and purge during burnouts. i don't see the point of hiding the purge, it doesn't have to be showy, but just do it under the car or something
Old 04-10-2006, 09:41 PM
DeltaT's Avatar
Purging into the exhaust is fine. Nitrous needs to be compressed and heated to release the oxygen. Nothing will happen.
Rather than waste it though, you could blow it onto your solenoids which will help cool them down and give you a more consistent hit. I've also seen people run an insulating sleeve over the nitrous feed line, then purge down into the sleeve to cool the line.
Jim
Quick Reply: Purge into an exhaust pipe
