382ci & 402ci H/C post your numbers.
Hi all,
I am between these 2 choices so far but I need to see some numbers from both combos.
post both N/A and the bottle.
M6 numbers r preffered
Thanks.
Thanks.
guys what is the biggest stroker I can go with stock crank and stock block? I am trying to benefit from every dollar in this setup.
ttttttttttttttttttttt
395 is the Biggest you can get with a LS1 block without resleeving. I have had mine for a couple years and going good. Texas Speed built mine and did a very nice job. You can resleeve the LS1 block but it is costly.
I missread your post you cannot have a stroker and a stock crank. I think they can regrind the crank and you would have an offset grind stroker but I wouldnt want one.
395 is what I have and I love it. I have no regretes with this set-up. With 12.1 comp. you will have to run race gas sll the time. I have 11.1 and that is perfect.
just spend the extra $1000 on a NEW 6.0 LS2 and build a LS2 402ci
or $600 on a NEW iron 6.0L bored .030 over, pushing displacement out to 408ci.
TSP is offering these starting around $3600.00.
although i didnt go with them, i picked up a LS block for $800.00 and got a local machine shop to cut me a deal that was competitive to TSP and SDPC, using a forged eagle 4' crank, forged eagle H bean rods, diamond pistons w/valve relief, nitrous rings, ARP main bolts. everything balanced and blueprinted. my cylinders were bored .005 over, making displacement technically 403ci. plus they let me pay what i could to get started and pay the balance once it was done. reusing my LS6 heads with a port and polish job stock valve sizes 308-314cfm@.600 lift. .608/.612 248/254 112 cam, im expecting 500-525ish, 470-480tq to the wheels on 11:1 compression. it should be done around 5/20/06.
now since ill have a LS6 block left over, probably going to take it to a 395ci and have it put in my girls '02 SS so she can kick some *** too.
