Dropped 60ft .35 with 17 inch MT Dr's.
Wound up going 12.50 at 110mph on 1.74 60 ft. Only prior 60 ft was 2.09 after 5 passes prior visit on BFG KD's. Only got one good pass all day at Atco. Next pass got a 1.75 60 ft and missed 2nd.
Tires were at 26 psi. Did little 1st gear clean off and dumped clutch at 5200 rpm. No spin. MPH is lower than expected consider some tuning i have done. Smelled clutch on dyno in 4th gear 2 days prior. Think that is an issue now.
These tires can be ice cold and they still dead hook on the street at 30 psi. Driving on them is another story...
Going for 11's with stock cam and M6 on street rims. Next up, long tubes, ypipe, ls7 clutch, aluminum flywheel, and pulley. And more track time...
Will post video shortly.
