dyno wideband vs my wideband??
Old 04-10-2006, 05:26 PM
brad8266's Avatar
Default dyno wideband vs my wideband??
I dynoed today and was slighty richer an their dyno, about a half a point than what I got on my wideband. They said that the dyno wideband is more accurate than mine because everytime they fire up the dyno, their wideband has the ability to recalibrate itself to the current air. Anyone know about that??
Old 04-10-2006, 05:51 PM
jdaniels's Avatar
Originally Posted by brad8266
I dynoed today and was slighty richer an their dyno, about a half a point than what I got on my wideband. They said that the dyno wideband is more accurate than mine because everytime they fire up the dyno, the wideband has the ability to recalibrate itself to the current air. Anyone know about that??
Were the sensors in the same general location?
Old 04-10-2006, 05:53 PM
brad8266's Avatar
No they stuck theirs in the tailpipe, mine is right after my header. I have dumped true duals with no cats.
Old 04-10-2006, 08:54 PM
BAIN's Avatar
Your's would be more accurate since they stuck theirs in the tailpipe.
Old 04-10-2006, 09:01 PM
slow's Avatar
What kind of wideband was used on thier dyno, and what kind of wideband do you have?
I would trust a NTK based AFM100 or Horiba sensor on a dyno, before I would trust a LC1/LM1 type bosch consumer level sensor. Being richer in a tailpipe is opposite what would happen if it was not as accurate. If it was leaner I would trust yours vs a tailpipe.
Ryan
Old 04-10-2006, 09:05 PM
brad8266's Avatar
My sensor is a Bosch. They were very close though. i am going back tommorow and logging the AFR with my wideband and laptop and will compare it with their wideband readings
Old 04-10-2006, 09:06 PM
brad8266's Avatar
I have no cats though so that makes a difference. They should be the same.
Old 04-10-2006, 09:38 PM
silverTA2002's Avatar
I don't know about which one to trust.
What I'd worry about more is at what A/F ratio you made the most power on the dyno.
If theirs says 12.5 while yours says 13.0 and you're making the most power at that point, does it really matter what the "actual" number is?
Old 04-10-2006, 09:41 PM
brad8266's Avatar
No it doesnt make much difference. Mine was at 13 on the street and theits was 12.5 on a dyno, dont really know if it is loaded to the weight of the c ar though. I am going back tommorow and bringing my laptop.
Old 04-11-2006, 12:08 AM
Assassin's Avatar
I got a dynojet wideband commander and the bung is mounted about halfway between the engine and tailpipe, the shop stuck the long wire type in the pipe and mine was .1-.2 richer than the wideband(dynojet) at the dyno shop, close enough for me..
Old 04-11-2006, 12:13 AM
ls1408cp's Avatar
Correct me if I am wrong but i thought on the street cars always run leaner. Thought I read that before
Old 04-11-2006, 07:42 AM
brad8266's Avatar
I thought that as well since I dont think the dyno loads the wheels to full vehicle weight.
Old 04-11-2006, 07:50 AM
Coal Mining Director
onfire's Avatar
If you are comparing a street run wideband to a dynojet wideband, the street should be roughly 0.50 af leaner since the DJ doesn't load the engine like the street. You should be closer than 0.5 if you run both widebands on the dyno at the same time.
Old 04-11-2006, 10:51 AM
kp
kp's Avatar
Dynojet uses an LSU sensor.
I would log the sensor in your car and use yours on the dyno for tuning since thats what you will be using away from the dyno
Old 04-11-2006, 12:40 PM
brad8266's Avatar
Well i went and dynoed again today with my wideband logging on my laptop and the dyno wideband. My logs were around .5 leaner than the dyno. Close enough for me.
Old 04-11-2006, 12:56 PM
SSpdDmon's Avatar
I do believe cars run richer on the Dynojets than they do on the streets. That's why tuners prefer Mustang dynos -- because the place a simulated load on the motor. That could be a part of it. However, did you ever check/adjust for any ground offset with your WB? If the WBO2 sensor is sending a voltage of 2.0V but the laptop is only reading 1.8V, that could account for the other part of the difference. Take an LC1 for example. AFR is roughly calculated by taking sensor voltage (V) times three (3) and then adding 7.35.
((V*3)+7.35)
If your sensor reports 2V, then that calculates out to be about 13.35AFR. But if your laptop is reading 1.8V due to offset, then it'll show as 12.75AFR in your log. If your laptop is reading 2.2V due to offset, then it'll show as 13.95AFR in your log.
Basically, this means your log will be off by +/-0.3AFR for each +/-0.1V difference between what the sensor is sending and what your laptop reads.
Old 04-11-2006, 02:04 PM
oange ss's Avatar
airflow into the engine on the street will also skew the reading
Old 04-11-2006, 02:25 PM
70Stang's Avatar
This dyno was done at our shop...We use a DynoDynamics dyno, not a DynoJet.
Brad was happy with the AFR results from today.
Old 04-11-2006, 03:08 PM
brad8266's Avatar
yeah, was all good today.
