Can you swap a 2 series rear with a 3 series?
Old 04-10-2006, 07:36 PM
Dustin's Avatar
Default Can you swap a 2 series rear with a 3 series?
A buddy has a 3 series lying around and I needed a new rear...mine is a 2 series..so I was wanting to know if we could swap them without any problems...or what would I have to do to make the 3 series work?
Old 04-10-2006, 07:49 PM
LS1Tech Sponsor
Scott@DrivelineSolutions's Avatar
What ABS system are you running? 3 or 4 chanel?
Old 04-10-2006, 08:06 PM
2001NBMZ28's Avatar
I originally had 2.73's and swapped in a complete 3.42 rear from a M6 car, neither car had TCS and it works fine.
Old 04-10-2006, 08:36 PM
Dustin's Avatar
How would I find that out?
Old 04-10-2006, 09:07 PM
2001NBMZ28's Avatar
3 channel (no TCS) has one sensor connection on top of the pumpkin, 4 channel (TCS) has sensors at each rear wheel.
Old 04-10-2006, 11:14 PM
Dustin's Avatar
Good info, thanks!
Old 04-11-2006, 03:38 PM
Bad Habit Bird's Avatar
If you have traction control you have a 4 channel, if you don't it is a 3 channel.
Old 04-11-2006, 04:19 PM
Dustin's Avatar
yah i was talking to Bryan earlier..i thought he had a 4 channel but he has a 3 and I have a 4.
Old 04-12-2006, 10:46 PM
Pavlock Performance's Avatar
i kindof wonder about the same thing... the case has to be the same but why cant you just stick whatever series carrier in the case??
