PCM Diagnostics & Tuning - ECU trouble
View Full Version : ECU trouble
Ryan'sSS
04-11-2006, 09:23 PM
I've been having trouble getting my Autometer tach to work. I've sent it back to Autometer a few times and it sill doesn't work. Its calibrated for the 5 volt signal, so that's not the problem.
One problem I do have is when checking the voltage out of the ECU it reads .14 volts DC. Is it possible that my ECU is bad? The car runs fine now.
My ABS light is lit. I thought that it was from putting in a 9" rear in but could it be from a low voltage reading from that pin? (Pin 10)
Ryan'sSS
04-12-2006, 07:55 AM
Need some help please.
jimmyblue
04-12-2006, 08:59 AM
There are some tachs which load down the tach signal
too much to work as-is, the drive is weak on this
"convenience" output. You may need to add a pullup
resistor to get the necessary swing (this is not a DC
signal and measuring it with a DMM will tell you little).
Try clipping something like a 1K resistor from the tach
wire to one of the PCM +5V outputs and see it things
start working for you. Supposedly the average voltage
should be 2.5V as you'd expect off a square wave 5V
signal. Some pullup assist might make that happen if
it's just a line loading deal.
Ryan'sSS
04-12-2006, 09:55 AM
Ok, stupid question here. Where can I find a +5 volt signal, i.e. which wire?
Ryan'sSS
04-12-2006, 03:48 PM
ttt...
Ryan'sSS
04-13-2006, 07:37 AM
bump..
jimmyblue
04-13-2006, 09:05 AM
'99-'02 PCM connector pinout info:
Connector Part Information
PCM Connector C1 12191489
80 Way Micro-Pack 100W Series Sealed (BLU)
Pin
Wire Color
Circuit No.
Function
1
BLK
451
PCM Ground
2
LT GRN
1867
12 Volt Reference
3
PNK/BLK
1746
Fuel Injector 3 Control
4
LT GRN/BLK
1745
Fuel Injector 2 Control
5-7
Not Used
8
GRY
596
5 Volt Reference
9-10
Not Used
11
LT BLU
1876
KS 2 Signal
12
DK BLU/WHT
1869
CKP Sensor Signal
13-16
Not Used
17
DK BLU
1225
Transmission Fluid Pressure Switch Signal B
18
RED
1226
Transmission Fluid Pressure Switch Signal C
19
PNK
439
Ignition 1 Voltage
20
ORN
340
Battery Positive Voltage
21
YEL/BLK
1868
Low Reference
22
Not Used
23
GRY
720
Low Reference
24
Not Used
25
TAN
1671
HO2S Low Signal Bank 2 Sensor 2
26
TAN
1667
HO2S Low Signal Bank 2 Sensor 1
27
Not Used
28
TAN/WHT
1669
HO2S Low Signal Bank 1 Sensor 2
29
TAN/WHT
1653
HO2S Low Signal Bank 1 Sensor 1
30-31
Not Used
32
GRY
48
CPP Switch Signal
33
PPL
420
TCC Brake Switch Signal
34
ORN/BLK
434
Neutral Safety Switch Signal
35
Not Used
36
BLK
1744
Fuel Injector 1 Control
37
YEL/BLK
846
Fuel Injector 6 Control
38-39
Not Used
40
BLK
451
Ground
41
Not Used
42
DK GRN
335
Low Speed Cooling Fan Relay Control
43
RED/BLK
877
Fuel Injector 7 Control
44
LT BLU/BLK
844
Fuel Injector 4 Control
45
GRY
474
5-volt Reference A/C Refrigerant Pressure Sensor
46
GRY
474
5-volt Reference Fuel Tank Pressure Sensor
47
Not Used
48
GRY
416
5-volt Reference MAP Sensor
49-50
Not Used
51
DK BLU
496
KS 1 Signal
52
Not Used
53
BLK
407
Low Referecne Transmission Temperature Sensor
54
BLK
407
Low Reference MAP Sensor
55
Not Used
56
Not Used
57
ORN
340
58
DK GRN
1049
ECM/PCM/VCM Class 2 Serial Data
59
Not Used
60
BLK
452
Low Reference
61
PNK/BLK
632
Low Reference Camshaft Position Sensor
62-64
Not Used
65
PPL
1670
HO2S High Signal Bank 2 Sensor 2
66
PPL
1666
HO2S High Signal Bank 2 Sensor 1
67
Not Used
68
PPL/WHT
1668
HO2S High Signal [Bank 1 Sensor 2
69
PPL/WHT
1665
HO2S High Signal Bank 1 Sensor 1
70
BRN
1174
Oil Level Switch Signal
71-72
Not Used
73
BRN/WHT
633
CMP Sensor Signal
74
YEL
410
ECT Sensor Signal
75
Not Used
76
BLK/WHT
845
Fuel Injector 5 Control
77
DK BLU/WHT
878
Fuel Injector 8 Control
78
Not Used
79
GRY or WHT
587 or 687
Skip Shift Solenoid Control M/T or 3-2 Shift Solenoid Control A/T
80
BLK
407
Low Reference
PCM Connector C2 12191488
80 Way Micro-Pack 100W Series Sealed (RED)
Pin
Wire Color
Circuit No.
Function
1
BLK
451
Ground
2
BRN
418
TCC Solenoid - Output - PWM
3
Not Used
4
PNK/BLK
429
Air Injection Reaction Solenoid Relay - Coil - Control
5
Not Used
6
RED/BLK
1228
PC Solenoid Valve High Control Sol.A
7
Not Used
8
LT BLU/WHT
1229
PC Solenoid Valve Low Control Sol.A
9
DK GRN/WHT
465
Fuel Pump Relay Control Primary
10
WHT
121
Engine Speed Signal
11-12
Not Used
13
WHT
85
Cruise Control Engage Signal
14
RED/BLK
380
A/C Refrigerant Pressure Sensor Signal
15
RED
225
Generator Turn ON Signal
16
Not Used
17
DK GRN/WHT
762
A/C Request Signal
18
DK GRN
59
A/C Compressor Clutch Supply Voltage
19
Not Used
20
LT GRN/BLK
822
VSS Low Signal
21
PPL/WHT
821
VSS High Signal
22-23
Not Used
24
DK BLU
417
TP Sensor Signal
25
TAN
472
IAT Sensor Signal
26
PPL
2121
IC 1 Control
27
RED
2127
IC 7 Control
28
LT BLU/WHT
2126
IC 6 Control
29
DK GRN/WHT
2124
IC 4 Control
30
DK BLU
229
Fuel Enable Control
31
YEL
492
MAF Sensor Signal
32
LT GRN
432
MAP Sensor Signal
33
DK BLU
473
High Speed Cooling Fan Relay Control
34
DK GRN/WHT
428
EVAP Canister Purge Solenoid Control
35
Not Used
36
BRN
436
AIR Pump Relay Control
37
DK GRN
83
Cruise Control Inhibit Signal
38
Not Used
39
RED
631
12 Volt Reference
40
BLK
451
Ground
41
Not Used
42
TAN/BLK
422
TCC Solenoid Valve Control
43
DK GRN/WHT
459
A/C Clutch Relay Control
44
LT GRN
1652
Reverse Lock Out Solenoid Control
45
WHT
1310
EVAP Canister Vent Solenoid Control
46
BRN/WHT
419
MIL Control
47
YEL/BLK
1223
2 - 3 Shift Solenoid Valve Control
48
LT GRN
1222
1 - 2 Shift Solenoid Valve Control
49
Not Used
50
DK GRN/WHT
817
VSS Signal
51
YEL/BLK
1227
TFT Sensor Signal
52
Not Used
53
GRY/BLK
1687
Ignition Retard Signal
54
PPL
1589
Fuel Level Sensor Signal
55-56
Not Used
57
PPL
719
Low Reference
58-59
Not Used
60
BRN
2129
Low Reference
61
BRN/WHT
2130
Low Reference
62
Not Used
63
PNK
1224
Transmission Fluid Pressure Switch Signal A
64
DK GRN
890
Fuel Tank Pressure Sensor Signal
65
Not Used
66
PPL/WHT
2128
IC 8 Control
67
RED/WHT
2122
IC 2 Control
68
DK GRN
2125
IC 5 Control
69
LT BLU
2123
IC 3 Control
70-75
Not Used
76
LT GRN/WHT
1749
IAC Coil B High Control
77
LT GRN/BLK
444
IAC Coil B Low Control
78
LT BLU/BLK
1748
IAC Coil A Low Control
79
LT BLU/WHT
1747
IAC Coil A High Control
80
Not Used
Courtesy of MattH
Ryan'sSS
04-13-2006, 09:14 AM
Thank you very much.
Ryan'sSS
04-15-2006, 12:53 PM
Just got done trying that and it didn't work. Is there any way the drive could be fried?
Ryan'sSS
04-15-2006, 06:08 PM
Also, is there another place I can get a signal to drive a tach and a window switch?
LMCJ5
04-23-2006, 07:01 PM
Did you get that fixed yet? I got mine working by using a 1 k resistor from the tach line to the 12v that powers the tach.
LM
