For the Fast 90mm setup, whats needed exactly? bigger lid?
Obviously i know the fast 90 intake, NW90 TB, But what about an 85mm lid and 85mm Maf? Can i keep my stock maf, or will it be a restriction? Anyone still use the stock maf and normal lid with a fast 90setup?
Mike
Mike
Sure, there is a transition from a 85mm maf to whatever lid you are running--at the moment--I am lucky because my suncoast setup's opening is larger than 75 mm (as you can see in the pic), besides the fact a wide v-pattern vacuum area is placed right after the neck. Therefore [as you can see in the pic] the combination not only does not create a restriction, but it feeds the intake assembly plenty of air.
