STS issue or boost issue
Old 04-12-2006, 10:32 AM
Bankz27's Avatar
Default STS issue or boost issue
Since all bs is out of my system I started reading some of what is going on....my EBC is basically hooked up wrong and so right I am not leaving it alone at 5 psi...something I can fix in the future...but next issue
My car shuts down every couple of seconds. For example at the stop light I lose some battery power, car exhaust stops then picks back up, and engine feels like it is going to die...I dont know how to solve that issue..
Next issue I am having at 10 psi and 5 psi I am having the same issue. Issue is when I press on the gas to go when I hit max boost my car like stalls, bogs down and I dont go anywhere while the gas is floored so I let off it. I am not sure about this issue either. It stalls at 4 thousand rpms or max boost and then at 5 psi I can 1 mph a minute. I dont know if the EBC has something to do with or not but would be good to know.
________________________
Old 04-12-2006, 10:54 AM
MECHAM's Avatar
what do the autotap/efi/hp tuner logs say?
knock knock?
Old 04-12-2006, 02:38 PM
Bankz27's Avatar
I have the log file and when it goes from 0 to 5 psi starts at 5.5 kr then goes down to 2.0 kr...I know that is not good......so I was wondering would the EBC cause this and just running off the wastegate. I only can go up to 4 thousand rpms underboost then the car basically bogs down...
Old 04-12-2006, 02:50 PM
LastBlack02SS's Avatar
Sounds like a tuning issue.
Old 04-12-2006, 04:20 PM
Bankz27's Avatar
Well I believe it might be but I am still trying to figure that of tuning but it is weird though that a tuning issue may cause me from going past 5psi and 4 thousand rpms and stall down
Old 04-12-2006, 05:10 PM
TwoFast4Lv's Avatar
I had a simular issue years ago with my ATI. The injecters were locking. not sure if it is the same issue but it sounds farmilar. I changed injecters and problem went away
Old 04-12-2006, 06:57 PM
Bankz27's Avatar
I really hope that is not the case.....lol
Old 04-13-2006, 05:48 AM
OUTLAWZ RACING's Avatar
Talking Me too
I bought a set of 36# from GM when I wanted to go cam and nitrous
But luckly on the dyno befor I sprayed I did a base run and mad 88hp at 3,500 knocking bad and my tuner could not fix the injectors SOOOO I sent the 36 # back and put the stockers back on
Old 04-14-2006, 01:57 PM
Koncrete's Avatar
doesn't sound like an STS issue at all as your knock readings are horrible.... who tuned your car?
Old 04-14-2006, 10:07 PM
pdanrichey's Avatar
I agree...take it to the experts...dyno tune that nagga again if not done already. Somethings jacked up electronically.
