Need help with ATI Fan...............
I just got my car back from the shop. and drove it for a couple days, and now the fan does not turn on.
I have a SLP fan switch (that I only use when I'm parked, or if I'm in stop and go traffic)
But, I changed all the relay's, and it still won't turn on (not even with the SLP fan switch) I called ATI, and they said that their fans never go out.
HAs anybody ever had a problem like this?
I would check for blown fuse,s.
If ok use a test light at the harness close to the fan-connections and check for power, along with the splices. While turning on the SLP Override switch.
This should point you in the right direction, be it a fan or a power supply/control problem.
