to heads and cam or not, that is the question
I bought a 99 frc corvette. Im gettin a twin turbo system that will have twin 44 mm turbos. Will a set "that I already have" of patriot stage 3 2.08 heads and a futral F-4 226-226 / 575-575 on 114+4 make more power relieably on the same 10 pounds of boost than the stock heads and cam. Very simple question, drivablilty is very good with this setup so thats not a problem. What do you guys think ? How much more power if any ? I already know the stock bottom end will be at its max so I will have a very safe tune also.
Check out this Corvette that we added twin turbo's to. http://www.exoticperformanceplus.com...Car.php?car=26 Bob
That is a very good wright up. I have seen this car before and all I can say is Im glad I didnt buy the HP kit.
Compression will be 10.4
I have no power goal what it makes is what it makes. But Im sure it will make 550-600 rwhp.
If it would be safer to run lower boost but have the power of the heads and cam I would probably do it.
Any ideas om how much extra power it would make with 8 psi with new heads and cam over stock heads and cam.
Originally Posted by LSs1Power
Whats your compression?
LSs1Power how much are you running?
I'd sell the aftermarket heads and cam you have now and put the money towards a forged bottom end. You can keep you stock cam and heads and make plenty of power if setup right. A little porting and a cam swap later on will net more power and you'll not have to worry about the bottom end.
Thanks for the input. I think Ill be swaping the heads and cam this weekend . I hate working on cars.
might want ot think of a new hobbie if you hate working on cars....by turboing your car you are asking for alot more work.
Yes I meant that I dont enjoy working on them anymore. I love to race and go fast so if you dont have a **** load of money then I have no choise but to work on it my self.
