should have stayed stock
Old 04-12-2006, 09:45 PM
A502slo's Avatar
Default should have stayed stock
Well i went from stock 3.23 a4 to 3.42. richmond sportman gears. Well damn this thing HOWLS. When i am driving its not bad at all, alil lound but ok. Well when on Decell it would howl like crazy. replace all new bearning and all. I reused the stock Pinion shim and carrier shim. well have i done something wrong here. any ideas what it is.
Old 04-12-2006, 10:09 PM
co.6z28's Avatar
post a pic of the pattern. the gear guru's will chim in
Old 04-12-2006, 10:15 PM
INMY01TA's Avatar
Yes, you bought Richmond gears. Known for being noisy.
Old 04-12-2006, 10:16 PM
Wyoming T/A's Avatar
howl on decel is usually ring and pinion noise
Old 04-12-2006, 10:55 PM
LS1powerhouse02's Avatar
richmonds are known for making a lot of noise
Old 04-13-2006, 09:26 AM
Moderator
jimmyblue's Avatar
You're not supposed to reuse the crush collar, it's a
disposable piece and you crush a new one to get the
setup fitted to the new pinion. Then you shim the
chunk for contact pattern. If you take it apart again
you might consider a hard pinion spacer & shim kit,
that is reusable and won't get beaten down with age
and abuse.
Old 04-13-2006, 09:48 AM
777's Avatar
I guess I'm curious as to why you went from 3.23's to 3.42's. Not much of a difference for the price.
Old 04-14-2006, 12:32 AM
A502slo's Avatar
and abuse.
no sorry i used the new crush collar and all new bearings. my b/l .008 and i have the stock size shim in pinion. on Acell its ok, slight i mean slight whine. but on decell it howls like a mad dog. when up on the lift and put in gear the rear has a howl that comes and goes, also when driving it howls as u give a slight amount of throttle.
Old 04-14-2006, 12:34 PM
Moderator
jimmyblue's Avatar
Can't speak for him, but I did the same ratio swap on mine
(but stock GM gears) when I went to the T-2R since that
was a total pull-apart deal anyway.
