Routing O2 sensor wires with LT's
Old 04-13-2006, 12:38 AM
Shallow Bay's Avatar
Default Routing O2 sensor wires with LT's
Anybody have pictures of how they did it?
Old 04-13-2006, 12:59 AM
JRracing's Avatar
I zip tie them to anything I can to get them away from the headers. ANYTHING!
Old 04-13-2006, 07:18 AM
Juiced2000SS's Avatar
Exactly, I even zip tied the wire to itself so it would be shorter/tighter. Away from the headers.
Old 04-13-2006, 07:34 AM
NHRATA01's Avatar
Yeah it takes some creativity...I ziptied the driver's side to the motor mount, and passanger side to the frame.
Old 04-13-2006, 08:21 AM
hatdragracer's Avatar
I got one small vinyl dipped p-clip and bolted to one of the oil pan bolts on the driver side, so the lead went up and over the little cast fitting on the oil filter housing, through the p-clip and bundled up near the connector on the k-member.
Passenger side I zip tied to the tranny lines, crank/oil level/startere harness bundle and up to the connector where I bundled the extra lead.
The extensions are worthless...I went and got some of the 2002 C5 O2 sensors (Bosch 35111 I think)...they had tons of extra lead line.
This worked with my SLP headers anyway.
Old 04-13-2006, 08:23 AM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
I did both of these too!
Old 04-16-2006, 10:56 PM
About how much space is needed between the O2 sensor wires and headers before heat becomes a problem?
Old 04-17-2006, 12:19 AM
Anyone???
