Alot of noise coming from my Rear end...
Old 04-13-2006, 12:41 AM
SS DNA's Avatar
Thumbs down Alot of noise coming from my Rear end...
Lately my rear end got noisier. I only hear it or notice it when Im driving at slow speeds, like at 25-30mph. Lets say im driving, at around 25, then I let the gas go and just cruise and the noise starts. It sounds like there is loose parts in the rear end.
What do you guys things ???
Should I start saving up ?
Old 04-13-2006, 05:37 AM
EPP
EPP's Avatar
Yes it sounds like you are on your way to walking... When you are ready, I can have a Moser 12 bolt or 9 inch ready to ship in two days. Bob
Old 04-13-2006, 05:55 AM
mvonada's Avatar
First thing to do is pull the cover off the rearend and have a look see.
Old 04-13-2006, 07:56 AM
Kleeborp the Moderator™
MeentSS02's Avatar
Mine makes a lot of noise, just like you describe, but it is still holding. No sticky tires for me though...
Bob@EPP...can you get the Moser there and install it? I'll be moving to that area later this summer, and a 12-bolt is on the list.
Old 04-13-2006, 08:06 AM
Pontiacerator
RevGTO's Avatar
A lot of them do that - the so-called "marbles in a box" sound - and they can go for a lot of miles being noisy like that. My old 2 series carrier made a lot of noise like that. It's a liability of the design of the stock Torsen unit.
Old 04-13-2006, 09:08 AM
MeentSS02's Avatar
Yep...been told that many times. The more I beat the **** out of it, the worse it seems to get, but so far, so good.
Old 04-13-2006, 05:37 PM
SuperSam's Avatar
Have you recently installed gears in you're car?
Old 04-13-2006, 06:07 PM
8a8mfh's Avatar
Sounds like the front pinion bearing is bad or the nut is coming loose.
Old 04-14-2006, 03:53 AM
SS DNA's Avatar
I havent installed any gears.
as far as opening it and checking it, What should I look for ??? I just did a change of fluid on it and I didnt see any metal shavings or any broken parts....
Old 04-14-2006, 09:09 AM
dudas35's Avatar
Mine was making a noise similar to that, i thought the outer bearing was gone on the passenger side axle, took it out and it was fine. The inner end of the axle had some wear on it (around the edges) and i called and got a price for a new axle $355 from the stealership. I put it back together with the same axle and the noise completely stopped. I don't know what happened. I may have been low on fluid.
Old 04-19-2006, 02:17 AM
SS DNA's Avatar
Should I go with a 9'' or 12 bolt ?? Or a Dana 60?
My car is my daily driver, Although that is going to change by around christmas time of this year, I will get a beater and put the SS in the garage for crusing nights and when I feel like driving a very good looking car
Old 04-19-2006, 11:24 PM
Unstang's Avatar
I have a "howling" noise from the right rear. The rar leaks some fluid from the pinion seal, not sure how much it is down...Seemed to change after a few launches in the last week. I am changing the fuid this weekend... Anything I should look for?
