Fueling & Injection - Need fuel rail with fittings
ws6charged
04-13-2006, 04:54 PM
I need some info on good fuel rails with fittings, i know that fast makes them but not sure if you need the manifold or not but is there any others out there ? i dont wanna go aramotive cause i dont think they even give the options of fittings. Thanks for the help.
dnm12
04-13-2006, 05:18 PM
try nastyperformance Nate over there helped me out a whole bunch!!! He knows his stuff
227Hawk
04-13-2006, 09:07 PM
LS1 Speed can give you another option! :)
Hawk :devil:
Jeremiah
04-13-2006, 09:31 PM
Im sure Nate at Nasty performance can help you, I have heard nothing but good.
Dont buy Aeromotive rails, the fit is horrible. I am trying to make up my mind if I want to try to run them or not....yes its that bad.
Nasty N8
04-18-2006, 12:50 PM
We have offered our own fuel rails for the past 5 years with zero fittment issues. I also have a complete kit with all fittings and hose needed to connect to your factory fuel lines. The FAST ones only come with the imediate fittings off the rails still need several others to make them work. I have kits for those as well.
Nate
slt200mph
04-18-2006, 03:51 PM
Nate will hook you up..he took good care of me..shipped out the kit right away... :thumb:
ws6charged
04-19-2006, 03:55 AM
im using stock return lines but my feed line from the tank is -8an steel braided hose so would i need to get all the fittings? i am also gonna hook up a fpr but i dont think that has anything to do with it thanks nasty fa sho.
Nasty N8
04-19-2006, 12:59 PM
I can set up what you need from the rails to the reg and to you feed and return lines. What all do you have so far?
Nate
ws6charged
04-19-2006, 03:56 PM
so far i pulled the static regulater out of the tank, put my tank back in ran steel braided holse from the booster pump and i stoped right there due to i need a longer hose to make it up to the rail. i have the fpr , with -6an fittings, the hose from the pump are -8 3/8. but i also have my n2o comming in tommorrow so i dont know what i would need to play in with that it is the nx maf kit. I am 19 and doin all this for my first time so the help is tremendious thanks!
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
