pacesetter lt air pipe broken!!!!!!
Old 04-13-2006, 06:05 PM
circusboy's Avatar
Default pacesetter lt air pipe broken!!!!!!
i just got bake from the muffler shop. they fixed my header collector leak, but it was still puffing. i poped the hood when i got home thinking i had a header flange leak. i was going to tighten the header bolts and notice the driver side air tube had snapped off of the header. what can i out on the hole to fix it?
i bought these headers new and they have been on the car since december.
is there some kind of warranty on them?
Old 04-13-2006, 06:10 PM
daryl2cb@yahoo.com's Avatar
pretty sure that is manufacturer defect should be covered
here is some info
PaceSetter Performance Products
P.O. Box 56397
Phoenix, AZ 85079-6397
Phone: (602) 266-1964
Fax: (602) 650-1136
Hours: 8am-4:30pm MST M-F
Customer Support: tech@pacesetterexhaust.com
Copyright © 2002 PaceSetter Performance Products
Old 04-13-2006, 07:20 PM
circusboy's Avatar
can i put jb weld on the hole or plug it with something
Old 04-13-2006, 07:27 PM
00'WS6Rocket's Avatar
Well if emissions isn't a problem where you live, then just have a weld shop weld the hole shut, or you can rig up a small pipe to "jerry" fix it.
Old 04-13-2006, 08:34 PM
smmurf86's Avatar
here in fl we dont have emissions, i welded mine closed..not a problem.
Old 04-15-2006, 01:32 PM
circusboy's Avatar
i plan on getting a TSP catted y latter this year, so i need to keep my air.
last night i cut a 1/4"X2" strip of exhaust tape, bent it in half stuck in the hole. then i put some JB weld on it. it seems to be holding pretty good.
