need help????
need help????
my problems are :
1- the temp is not stayble , its jumping from 80 to 95 degree in wow and in high way run ..is that normal with FI cars.
2-the rpm reving at idel ?
3- get this codes:
P0113 : an intake air temp sensor failure
P1111 : another failure for the intake air temp sensor
P1626 : a vehicle antitheft code
how could i fix it ???
my car info.
98 indy 500./ 347 cid forged/ a@a p1 procharger / 14 PSI /ported heads/ custom cam 224/228/ 581 -114 / 24lb injectors/ racetoinx fuel pump / slp ajustable chine/ 1.8 rockers/z06 oil pump/ z06 intake / bbk 80m TB /LT header ceramic coated / off road x pipe / slp loud mouth exhaust /3.42 grear /3200 stall / custom tune by PCM FOR LESS / water injection / 160 thro./ngk tr8 pluges.
3- get this codes:
my car info.
