msd digital window switch(CYCLES)
everytime i hit it,if i releace the switch and hit it again it won't because it is going through the beggining phase again like when you first turn it on and it shows you the on and off rpm and the cylinder mode that it is on,and when is doing that the solenoids don't work,i just don't get why it cycles again.are you guys getting the same action,i lost a race cause of it.
i think my wot switch is giving power to the window switch,i followed one of nxricky's diagrams so i'm going to try and fix it tonight,if i find the diagram ill try and post it.
you don't need the gray wire if you use the yellow one as per instructions,as far as my problem goes i'm getting power now for the msd through a ignition activated fuse instead of the wot/activation switch and it seems to have solved the issue when i testdrove the car,only thing is now the window switch is always going to be on when i drive unlike before when it would only turn on when i armed the nitrous,i thing you were on the the money orange ss,we'll see when i run it again so now i gotta go find that car for the rematch.
Well, I think I found my problem. I am using the Window Switch to ground the solenoids. Which is what I thought the original diagram told me to do. I guess I read it wrong though.
Strike that, I have it connected to the FPSS switch, so my problems continue.
