Drag Racing Tech - Passenger side airbag pressure
View Full Version : Passenger side airbag pressure
Matt D
04-14-2006, 10:56 AM
What do you guys run in your airbag? I usually run 15-20 depending on the track/street conditions.
CAT3
04-14-2006, 12:46 PM
Our track was consistently shit, so I ran 22psi...when I remembered to air the MF up.
Now our track is closed and sometimes I feel bad for talking bad about her, but oh well.
FANTAZ28
04-14-2006, 12:57 PM
both of those seem high, if i run anything more than like 10 psi the car bounces off of it! it will pick up the wheel than slam it down and pick it up again..... so i dont run it at all, stock sway bar and all
http://www.ls1speed.com/byron05/4.jpg
z28racerlt1
04-14-2006, 02:46 PM
I used to run them in my car for a couple of years. I ran 15 lbs in the pass and 6-8 in the driver. I hated them because when the temp would change at the track so did the air pres. in the bags. I had to start checking them every pass.
Ken
smoknta
04-14-2006, 11:18 PM
Thats why I mounted guages on them in the spare tire well. I just have to open the truck and look at the guages.
