Generation III External Engine - need to i.d. a bolt
View Full Version : need to i.d. a bolt
patSS/00
09-19-2002, 10:25 PM
There's a bolt that goes into the block, a little above and maybe 3" forward of the oil filter (not the 2 bolts right above the filter) - anyone know what it is? It's small, maybe 10-12mm. Looks like a plug since it doesn't seem to be holding anything together. If it is a plug I'd like to put a sensor there.
<small>[ September 19, 2002, 10:28 PM: Message edited by: patSS/00 ]</small>
Dope
09-20-2002, 12:04 AM
Yank it and see if oil comes out. Then you can adapt it for oil pressure/temp <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Personally, I yanked the piece with the 2 bolts that you mentioned, and installed a sender there, using the corvette replacement (corvettes have oil temp sensors right there, I just bought one, used a brass adapter, and put in my autometer sender, and then bolted it back on).
Dope
nthnwbr
09-20-2002, 10:22 AM
It's not the cross bolt for the main cap is it? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
patSS/00
09-20-2002, 04:00 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by nthnwbr:
<strong>It's not the cross bolt for the main cap is it? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yeah I think it is. Guess I won't be putting a sensor there!
