tranny removal problem
Old 04-14-2006, 07:04 PM
MetallicaMatt's Avatar
Default tranny removal problem
hey everybody, just into my clutch install
and i cannot! get that last damned bolt on the Tranny. its the one at the very top, but the passenger side. Here is a hose and a wire loom in the way
any tips on how to get that last one out? I've got a 2ft straight extension, plus the usual 3", 6" (or whatever) and a swivel
I just can't get the damned socket on that thing
tips?
thanks!
Old 04-14-2006, 07:23 PM
2001z's Avatar
the way i did it is get alot of extensions and drop the end of the tranny for it will hang lower towards the ground and you should be able to reach it with no troubles
Old 04-14-2006, 09:21 PM
i got it off, i ended up using the 3" and 2ft extensions, and it ended up right where the shifter comes up, i poped the air rachet on from inside the car and busted it off
my question is, WTF is that stupid bracket doing there, its holding a small plastic hose that just sits ontop of the tranny, its capped...wtf is that for? do i really need it? cuz theres no way i'm putting that stupid little bracket back on lol
Old 04-15-2006, 12:00 AM
NVR_SPDS's Avatar
Its a breather line for the trans, and yes you need it. I dropped the rear of the trans, and it made it alot easier to reach. Ive had our tranny in and out more than id like (3 times in a week), so i guess i could say im pretty good at it now.
Old 04-15-2006, 08:55 AM
purple98haz28's Avatar
same here dropped the rear of trans a few inches and it was much easier to reach
Old 04-16-2006, 08:00 AM
Deeavi's Avatar
On mine I had to cut the y-pipe where it goes into the mid pipe, and then the rear of the tranny dropped right on down.
Old 04-16-2006, 10:27 AM
H8Mac's Avatar
I like to leave the bellhousing on when i remove the trans it makes getting to the bolts mush easier
