Tell me if these are the right injectors.
Old 04-14-2006, 11:12 PM
97SprChrgd383's Avatar
Default Tell me if these are the right injectors.
Ok. I had a 383 built with the lt4 conversion and a supercharger using 8lbs of boost with a fmu. I put 30 lbs injectors in it thinking this will be good. I call to get a dyno tune setup and we will say "BillyBob" said that my injectors were too small and it will run lean. Ok, so I decide not to go with the lt4 conversion and get some afr lt4 195's with standard port, a thunder racing blower cam, and a lt4 intake ported to fit a monoblade throttlebody and to the heads. Oh, and I put a smaller pulley on to use around 14lbs of boost. I took BillyBobs advice and put 42 lbs ford injectors into my car and took off the fmu. I call BillyBob back to set up another appt. to get a dyno tune. Once again BillyBob said my injectors are too small. That it would run lean. What the hell does a guy gotta do to get a dyno tune around here. I think the 42's are plenty big. What do you guys think?
Old 04-14-2006, 11:17 PM
94greencamaro's Avatar
I think BillyBob is right. 14lbs is too much boost for only a 42lb injector. Go to the fueling and injection section and they have a sticky that will link you to a calculator that can give you the proper injector size you need.
Old 04-15-2006, 07:15 AM
EPP
EPP's Avatar
Yes, Billybob is not steering you wrong. The 42's would of worked well for you when you were shooting for 8 psi. I'd go with 60lb injectors now that you have bumped the boost up into the 14 psi range. Bob
Old 04-15-2006, 08:20 AM
96capricemgr's Avatar
Dude, you needed to do this research BEFORE you bought all the wrong parts.
Old 04-15-2006, 04:04 PM
All the wrong parts? And it takes how long to change out injectors? Ok. What other wrong parts are you talking about? Just curious.
Old 04-15-2006, 04:35 PM
Ls1Bait's Avatar
what happened to the 30lbs injectors.
Old 04-15-2006, 05:03 PM
Sold them. I'm also selling the 42# injectors it appears.
Old 04-15-2006, 05:12 PM
ss97dml's Avatar
I'm Running 60# Injectors With A 383 And 8lbs Of Boost.AND TAKE OFF THE FMU,YOU DON'T NEED IT WITH THE BIGGER INJECTORS.
Old 04-15-2006, 09:43 PM
I took that off. What 60# injectors are you running?
