383 Lt1 What Hp ##???????
Old 04-15-2006, 08:09 AM
FIREHAWKONNOS's Avatar
Default 383 Lt1 What Hp ##???????
Looking At A 383 Lt1 Stock Heads With The Hot Cam Kit What Kind Of Numbers Would I See With Long Tube Headers,58mm,3'' Slp Exhaust No Cats,in A T56 Car
Old 04-15-2006, 08:18 AM
96capricemgr's Avatar
That is a horrible setup and I would not trust anyone who would actually put it together with that poor a parts selection. It would be so weak head/cam stock bottom LT1s would would have no problem walking all over you. The stock castings are good but require porting if you want them on a 383 and can perform wonderfully if ported and just bolted to the stock shortblock with a cam upgrade. The HOT cam is a mediocre chopice for a 350 and downright poor choice for a stroker. You want to drop a couple grand on your car do the topend first then the bottomend with a new cam to compliment it down the road.
People say there is "no replacement for displacement" BUT if you don't let that displacement breath it wont work.
Old 04-15-2006, 08:57 AM
My Cars Got No Motor I Just Found This Motor I Already Have The Other Parts That I Listed He Says The Heads Are Mildly Ported And Cleaned Up So I Figure Thats Pretty Much Stock Heads He Most Likely Bought That Dam Hot Cam Kit After Reading It Will Make 425 Hp Which It Doesnt I Think I Would Change The Cam To A Gm 847 Or A 236/242.556/.576 Lsa 113 To Start Then When More Funds Are In Myhand Get A Set Afr 195 Cp Heads But My Question Is The Way This Motor Sits What Knids Of Hp Will It Make I Know Other Guys Out There Have Tried These Hot Cam's On Stroker Motors.
97blkz's Avatar
This car is being choked to death, i agree with 96 bad combo!!! Heads need to be ported at the min and that cam is weaksauce!
Old 04-15-2006, 09:08 AM
Who Out There Can Reburn Me Program For My Ecu I Live In Winnipeg And No Body Out Here Does This,i Want The Knock Senser Removed,tuned For What Ever Cam I Do Go With,egr Removed And All The Air Stuffon The Intake Removed?and If Possible The Rear 02 Senser Dont Want To Run A Simualtor
Old 04-15-2006, 09:28 AM
Lethal Z's Avatar
I would check out www.madz28.com Ion did a great job on my set up, theres a sheet on the website you need to fill out and go from there.
Quick Reply: 383 Lt1 What Hp ##???????
