Screw up or Coincidence????
Ok guys last night i changed all my plugs, wires, and my belt, and put in a 160 deg. stat. it ran good last night, and this mornin but today my power sterring began to slip and come to find when i got home water was pourin out from under car, im thinkin(almost positive) its waterpump that just went out???? is this jsut coincidence or did the 160 deg stat screw stuff up or wut? and about the steering it was kinda like come go, cuz the water was pourin on to the belt right there probally causin it to slip? so wuts the deal coincidence or did something screw up when i put stat and stuff in
yea belt was on good it was tite and in all teh grooves and i flushed collant and added new coolant and it was spinnin and it kicked on last night fine after stat install and all?? wut in the world???
o i see im almost positive i did tighten the thermostat housing, but now that i think of it i didnt bleed the system b/c my old car didnt need that, is bleeding it necissary??? and if i didnt would this cause my water pump to blow or is it jsut a pressure valve that opens to save the water pump??? please i need help soon cuz if i blew waterpump i gotta buy it so i can fix iit tommorow
Originally Posted by djkyle25
parts store gonna be closing soon, ne one????
Did you check the T-stat housing for leaks or is it leaking from the pump? Is a hose clamp loose, did you put a hole in a hose during the install, etc? No one can do the final trouble shooting over the internet.
My money would be on the T-stat housing or something that you worked on recently, since the trouble started right after a repair. Since an LT1 water pump is not driven from the belt, I believe the belt install is a non-issue.
Good luck!
Mike
ya thnaks alot, i jsut ran it and once it started circulating water WAS SPRAYIN up in a fine like mist from under the intake elbow, so im thinkin it was water pump
You need to bleed the system after you install a thermostat. That little bit of air in the system will produce the loss of coolant you describe. I've been through that twice.
