95 opti on a 94?
Old 04-15-2006, 02:20 PM
LT1MAN's Avatar
Default 95 opti on a 94?
will a vented pin drive optispark for a 1995+lt1 camaro work on a 94 lt1 camaro? i may have to buy one soon and i would like to get the better one if possible, anyone done this upgrade?
Old 04-15-2006, 02:29 PM
Honda Hunter's Avatar
Here is what you will need.
http://www.noid.org/~muttvette/opti.html
aboatguy's Avatar
It is not as simple as pull the non vented and bolt in the vented opti. You will need a 95 up front cover, opti harness, and other assorted parts.
dang I was beat to the punch!
Old 04-15-2006, 02:32 PM
I own the net.
Old 04-15-2006, 02:55 PM
justav6iswear's Avatar
good timing with this one, im doing the same thing! thanks!
Old 04-15-2006, 10:39 PM
Jeff@ramchargers's Avatar
I just did this and finished about 3am last night. You will need the 95 front cover, vented opti, 95 opti harness, vaccuum vent hose, and a 95 and newer camshaft or an aftermarket one. The center hole on the 94 is smaller then the one on the 95+ camshaft. works great though. I have been driving it all day without a problem.
