Did Pacesetter lt's yesterday
Everything went easier than expected, lots of help from reading all the posts on here. I got rid of the AIR and EGR. I was confused on the "frost plug" for the EGR until I read more this morning. The one I ended up getting was actually called an expansion plug, 1 3/8"-1 1/2" diameter. We put both headers in from the bottom, removed the #5 cylinder spark plug to get the driver side in. Only problem was getting the oil dipstick tube out, it didn't break, but I mangled the end pretty good and have a new one ordered.
Originally Posted by stillremains
Where did you order a new one from?
Originally Posted by jmm98LS1
Because it runs in between the primary tubes for #4 and #6 cylinders.....can't remove/install headers with it in place.
so do you have to drain your oil to do this? and how do you remove your dipstick?
Im asking because i ordered pacesetters and I just want a heads up..
No, you dont have to drain the oil. I think it actually goes into the block right above the pan, around the front of the starter. There is a bolt in the head you take out, then just pull on it. Hopefully your comes out easier than mine, I ended up grabbing it with channel locks, and I still had to pull hard, and try twisting and rotating it.
and pull up gently....it will come!!!! DO NOT BEND IT!!!
it was CAKE
e
i removed my coil packs....just to make it that muchj easier...probably another hour in the project taking your sweet *** time..made things easy, plus i did new wires and all soooo
try it
try it
