LTFT's way off the chrat!
Old 04-15-2006, 04:36 PM
BAD FNZ's Avatar
Default LTFT's way off the chrat!
Finnally got everything running right and got the dashboard to work with EFI Live, but it says my LTFT's are at 25%! I don't know if this is right or if the software is just freaking out. How do I lower the LTFT's, I know the ideal percentage is -4 - +4% but how do I get it there? Any help would be great. BTW this is on my WS6 not the Z06
Old 04-15-2006, 04:46 PM
brad8266's Avatar
how long did you log for and were the trims already learned? If so then you have a problem. What are your mods??
Old 04-15-2006, 08:11 PM
BAD FNZ's Avatar
My mods are stage 3 5.3 heads, 224/230 cam, MAC mids and the LS6 intake. I logged all day today at the track, and a good 2 hours worth of street logging. I cleared the trims before I went to the track today, and it looks like they're all screwed up now.
Old 04-15-2006, 08:58 PM
white2001s10's Avatar
25% is the max correction it can learn.
Was this just at idle or in other cells as well?
It's very easy to get a +25% at idle if you have a large vacuum leak around the TB, the power-brake hose, or even an intake that didn't seal correctly.
Old 04-15-2006, 09:37 PM
BAD FNZ's Avatar
Thanks for the idea.. I'll go check that here in a min... But it's +25% all the time.. I'm new to tuning so I don't know how to reset any the the trims, or how to dial them in. Any other help would be great!
