crank position sensor
While driving yesterday afternoon, my car began to sputter backfire through the exhaust,then shut off. I put it in park and turned the ignition off. Turn the key and the car statted right up and drove home perfectly.
Later that night on my way to work my car did the same thing, Sputter, backfire through the exhaust, and then shut off. This time a friend was driving behind me and said that flames shot out of my mufflers. Again the car started right back up, but repeated the problem about three miles later.
I drove home this morning (eight hours later) without any problems. When I got and ran HPT, it showed a code for my crank position sensor. I cleared the code and let the car run until it reached operating temp. No problems.
Any advice or comments would be helpful. thanks.
Originally Posted by BIGSAM99Z
So how do you do the relearn after installing the sensor. I have HPT but can't figure out how to do it.
in scanner, vcm controls... bottom of the above URL shows CASE procedure
Don't know. I don't have HPT, I just swaped the sensor cleared the code and it ran good for about 2 weeks. Now its acting up again. Can't figure out how it ran 60k miles without a problem and now I have had 2 go bad in the last 1k miles.
I cleared the code and it has run fine for the last day and a half. I picked up the new part today, but I think I will wait a couple of days and see what happens.
