Catted Y-Pipe Fit Question?
Old 04-16-2006, 01:32 PM
FormulaNHRA's Avatar
Default Catted Y-Pipe Fit Question?
I'm goin to be getting pacesetter lt's with the tsp catted y-pipe. I currently have on an slp lm and the slp ory (dumping for the header and ypipe setup). Will the ypipe and headers slide right up to the end of the catback or will there be some fitment problems and require grinding, cutting, etc??
Old 04-16-2006, 02:17 PM
LastHawk02's Avatar
what color NHRA
Old 04-16-2006, 10:19 PM
2000 formula, black
Old 04-17-2006, 06:53 PM
LastHawk02's Avatar
i see, i always see a red one around this area thought it was you
Old 04-17-2006, 07:24 PM
AdamSS's Avatar
I think it should be ok.... to be 100% sure, call TSP and ask. They make the catted Y-pipe
Old 04-17-2006, 07:29 PM
2K2WS6TA's Avatar
They should fit in the catback, my pacesetter y fit into my TSP Rumbler fine (a little wiggling of the Y pipe, and cussing it helped )
Old 04-17-2006, 09:48 PM
LS1Zedder's Avatar
I have the loudmouth and the TSP catted Y too. had to do a bit of coaxing to get it together. We also had to cut about 1" off the back of the Y pipe to get it to go into the LM. Had to hit the inside of the LM with a small die grinder a bit. Then grease it up with wheel bearing grease then hammer her in to the Y pipe. It will go. First time putting it on takes some patience and a BFH. You will love how its sounds though. Sounds mean!!!!!
Old 04-17-2006, 10:00 PM
thanks guys, I always like a little struggle but just wanted to make sure it wasn't anything I couldn't handle
