Anyone here of Ferrera Valves and Springs?? I need some help
Old 01-20-2003, 06:41 AM
unstable Vic's Avatar
Default Anyone here of Ferrera Valves and Springs?? I need some help
A local head porter from the School of Automotive Machinests(SAM) is porting a set of heads for me, and wants to use Ferrara valve, springs...etc. Are they any good??? thanks guys, victor
Old 01-20-2003, 01:21 PM
1dirtyZ's Avatar
Default Re: Anyone here of Ferrera Valves and Springs?? I need some help
i'm using ferra valves, they work great!
i don't know about the springs...
Old 01-20-2003, 01:54 PM
AlonzoVersion 1.0's Avatar
I am not sure about the springs.Is he gonna give you a warranty on the parts?If so then try em out.I doubt they would steer you wrong though.
Old 01-20-2003, 03:20 PM
Dean98TA's Avatar
I've heard the Ferrea valves are heavier than others, meaning you will need stronger valvesprings. That might not be a problem if you are running solid lifters, but for hydraulic lifters it could be, depending on how high you want to rev.
A lightweight valvetrain is just as important as a lightweight rotating assembly for making power.
I opted for Manley valves in my application because I was informed they were a little lighter than the equivalent Ferrea valves. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old 01-20-2003, 06:46 PM
Angry'Z's Avatar
I'm running ferrea in my LT1 stroker - that's what GTP uses in their heads. Damned good valves, couldn't tell you about the springs.
Michael
Old 01-20-2003, 06:48 PM
horist's Avatar
I'm not sure about the springs, but I have those valves in my TEA S2 heads
Old 01-20-2003, 07:54 PM
GrannySShifting's Avatar
GTP has sent some recent heads out with Ferrea valvesprings. They dont use the same retainer as the stock/918 do.
We put their Stg II heads, 227/224 cam, Jethots, lid and ASP pulley on what was a factory stock car it made 410 hp with no tuning.
