Transmission Fluid
Transmission Fluid
I'm getting ready to change mine, just wondering if there are any write-ups on this?
I'm new to the LS1 scene so excuse the newbie questions about changing the fluid, have no idea what i'm doing............
Thanks
Thanks
For the T56 there is a plug that you put a 3/8 drive rachet into on the passenger side, it says drain near it cast into the side of the transmission.
On the drivers side there is the same type plug I'm pretty sure it says fill near it.
It takes four quarts dexron 3.
I used a hose adapter for the fluid bottles and rolled them up like a tooth paste tube to get all the fluid in there.
I put synthetic in mine and it didnt shift as smooth as with conventional, i'm guessing the syncros like the conventional better so I drained the synthetic and put conventional back in. I know you can do it through the shifter but since I dint want to take the console apart and risk dripping ATF inside my car I bought a "turkey bastor" style pump from Autozone for like $10. It looks like a grease gun, only with a clear hose on the end. It worked well, I used it when I changed my rear end fluid too...
FLWS6- Try taking a long slow read through the below thread...it's long, but should answer all your questions on this:
Which T56 fluid?
Chuck
Which T56 fluid?
Chuck
