Corvette Performance - gear ratio questions
I know the Z06 has different 1,2,and 3 gear ratios. I was thinking about changing the trans in my FRC to a Z06 spec unit for a little help down low, but was curious what youguys thought would you just change the diff. ratio or put in a built trans for similar money?
NEVRLIFT
04-16-2006, 08:49 PM
I'd just change the rear end ratio. A 3.73 in your car would be similar to the stock MN12 in the Z06. A 4.10 in your car is similar to 3.90s in a Z06.
mountainbiker2
04-17-2006, 07:52 PM
I believe a 3.90 rear axle matches the Z06 MN12 gearing, but only for the first 3 gears. 4th, 5th and 6th you get different gearing.
Steve
http://i12.photobucket.com/albums/a216/mountainbiker2/99Corvette1.jpg
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
