What stall for street/strip procharged 347?
Motor has a built bottom end with 10.1:1 compression. I will be adding truck heads and possibly thicker head gaskets to lower the compression. I am in the process of buying the Procharger setup that Moparnos had on this car. I believe it comes with a 11-13psi pulley.
I want some recommendations on stall size. I currently have a 4400 stall on it that I was using for the all motor setup, so I am thinking I need to go lower, possibly 3000-3500, correct?
I am having Ed Curtis design me a cam. I orginally was having him design a max effort all motor cam, but my setup has changed. I want to first get an idea of what type of stall I will need, and then have him design the cam based on the stall. Or should I be doing it the other way around? Mods are below.
thanks
thanks
I can, but I think I may be dissapointed.
I was at Markos shop three weeks ago getting it tuned for H/C, and in third gear the rpm's couldn't get over 6,100 rpms. Bill told me it was the converter for sure. I was getting major valve float as welll, so maybe that was contributing as well. But if the converter was being overpowered with the N/A setup, I hate to see what it do with a procharger.
It will be pretty loose probably, I would just try to see where you are at first so you have a point of reference. Most likely it will have to be tightened up a couple hundred rpm..
edit: If its that loose N/A you will be very disappointed when you put the blower on it. May as well get it changed now..
LS1Tech Co-Founder
The nice thing about Yank is that they used to restall converters for like $200-250.
My current TCT is stalling like 4500 with 18-21 psi. I might sell it. I was seeing 162mph on the dyno with it.
