Gears & Axles - A simple way to a quieter diff. ........
StevieZ
04-17-2002, 04:20 PM
For those of you who have a whine coming from your diff, (I'm not not talking about a chainsaw whine!) try putting in Redline shockproof heavy formulation gear oil . (70W250) I filled my diff with it today and 90% of the whine I had is gone. There is still a very slight whine at around 45 MPH but the whine from 60-70MPH is completely gone.
Black Sunshine/ 00SS
04-17-2002, 06:23 PM
Did you also add any GM limited slip to that?
Ragtop 99
04-17-2002, 07:10 PM
Does that stuff pour in or do you use a shovel? <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
I know a couple guys use the 85/140 and that seems to help too. Did you try that or go straight to the 250? Just wondering how big the difference is, if you know.
StevieZ
04-17-2002, 08:00 PM
I did some experimenting with diff oils in my Viper and had experience with this oil already.It is the quietest of all of them. I put in the Redline shockproof heavy in the Z when I changed to a T/A cover. Yes I added the additive.
<small>[ April 17, 2002, 08:06 PM: Message edited by: StevieZ ]</small>
Holes02
04-17-2002, 09:31 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Ragtop 99:
[QB]Does that stuff pour in or do you use a shovel? <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> QB]</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif"><img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
pedaltothemetal
04-17-2002, 11:57 PM
I've put heavier diff oil in and the diff got real hot! I think it is due to more friction of heavy churning oil.
Leo
Damian
04-18-2002, 12:28 AM
Holy shit that's thick!! I think I will stick to 85w140 for now. Keep us posted on how the rear end acts with some miles on the clock with this oil/malasses...
Josh
StevieZ
04-18-2002, 05:58 AM
You won't see heat from the Redline shockproof. In fact they garantee you will see lower temperatures.
Here's a quote from their website......
" ShockProofTM Gear Oil has a 40% lower coefficient of friction and 250% the load-carrying capacity compared to conventional gear oils, which means that metal- to-metal friction is greatly reduced. Temperature reductions between 25°F - 75°F are common in circle track, road racing, and off-road racing. Improved durability in high-performance use is the primary benefit of the Heavy ShockProofTM and along with the improved durability is an improvement in efficiency, but if further improvements in efficiency are desired, and durability is not a major concern, LightWeight and SuperLight ShockProof TM can be used."
BLUEBALLS ZZ
04-19-2002, 05:20 PM
if you want tom take it the whine out. get it reshimed. take out shiming and pull the gear back. it worked for me!! now my rearend is quite <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
