Head Install - P0300 Misfire Error
Just finished installing a set of Dart 205's. Car has a VHP cam which is 216/224 .551/.551 115LSA which is not too radical but is a little lumpy on idle. Had no codes prior to the heads, but now it is throwing the P0300 and when I look at which cylinder, it is all of them not limited to just one. I can't detect a misfire and the car absolutely runs fantastic from cold start to running hard. I have not yet had it tuned from the head installation, is this a normal thing to have happen?
I got the same code with my heads/cam install.
Check plugs/wire just to be sure, but most likely, the cam is confusing the computer into thinking it has a misfire.
I changed the misfire parameters at idle and no more code.
If you have a misfire in higher rpm ranges, that would be a different story.
Basicaly, blame the cam, tune it out.
I agree, its the cam.
You can set the code to not report same as you do for changing maf codes to no mil or whatever. Or better than that there are a whole lot of misfire tables that you can adjust to "tune" it out.
Take a look in your tuning software. Low rpm and maybe idle misfire tables.
In efi the tables are C5601 to C5627 loads to play with there.
