Drag Racing Tech
28" fitment questions
Old 04-17-2006, 08:24 PM
RaNsOm's Avatar
Default 28" fitment questions
Gonna be stepping up to a 28" tire from a 27". Right now I have a good 2-2.5" of clearance from the top of my 27" to the inner fender lip, so I can pretty safely say that it wont be hitting that, but what about the inside fender? Ive already banged the front side of the inner fender in a bit (from when my 315's rubbed), and also the lower front of the inner fender lip.
Is there anywhere else I should probably start massaging before I throw them on?
Old 04-18-2006, 05:22 PM
RaNsOm's Avatar
{cricket noise}
Old 04-18-2006, 05:41 PM
Z284thgen's Avatar
i allready had my fender lips rolled but had to beat the very front lower corner in ( so it wouldnt cut into tire while it grew at speed ) other then that i didnt have any issue with mine had them mounted on 15x8 5" bs telstars 28x10x15
i must say that adj lca's are a must
Old 04-18-2006, 07:07 PM
RaNsOm's Avatar
guess thats good news then. I have adj lca's and already have the front lower portion of the inner fender lip banged in and my welds are 15x8's.
Old 04-18-2006, 08:03 PM
ntense's Avatar
I take you probably already have a adj panhard rod, but what I did was on the front part of your wheelwell, where it curves back towards the bottom I took that straight down so I would not have any probs with the tire rubbing it and the end of the track.
Old 04-18-2006, 08:30 PM
RaNsOm's Avatar
yup I just got an adj panhard rod as well. thanks for the tips.
