Another MSD window switch thread.....
I have a 1998 W.S.6 and im trying to wire up the window switch. I just want to make sure i get the right pin. Its the white wire pin number 35 right? On circute number c2?
Thanks,
Miguel
Thanks,
Miguel
Restricted User
Just checked back with my old thread and got this link for you..
http://www.ls2.com/boggs/torques/98pinpcm.htm
So it is Pin 35 white wire on the Blue Side
I just put this in the other window switch thread, but anyway, you can also connect the window switch to the negative side of any one of the coil packs instead of trying to locate the correct pin on the PCM.
