90mm Fast Intake & T/B
Who is running this Fast 90mm TB & Intake? What kind of power can I expect by adding these bolt ons. I currently have a 600/601 lift cam on a 230/234 on a 112lsa. Will this set up better my current LS6 intake/ported tb?
Post up.....
Post up.....
i heard you may not see much more than maybe 10/15 hp/ tq. i believe they are more beneficial for the larger cube motors. i will be going with the same setup but all i had is a stock intake and ported t.b.
dont quote me on those numbers.
I was thinking about the same thing, but I think for a cammed car a ls6 and ported TB should be fine, maybe youll gain a few HP with the FAST. Our cams are similar in size as well.
Really 5-10 whp/tq depending on cams for stock cubes. Mine netted about 7whp and the best I have had a customer do is about 11whp. Its that last little touch to get them maxed out.
Brandon
Brandon
Originally Posted by 408WS6
I'm holding out hoping that something even better than FAST will come out in the next 6 months - 1 year. If not, I'll probably go with a FAST.
Brandon
Originally Posted by xfactor_pitbulls
There already is something. A heavily ported vic. jr. It will flow more, but do you have the engine to pull more. Or if you are a big dog, go grab a harrop.
Brandon
Brandon
You would have to use a 90 degree elbow mounted on top of the intake manifold inorder to retain the stock air box, it may not fit under a stock hood.
I have a 408. Will that (Victor Jr) fit under a stock hood?
Originally Posted by jeremym
I gained 24rwhp and 10rwtq on a H/C stock cube motor.It is in the retune w/ the 90/90 combo
Brandon
Yeah, thats what I thought. I was aware of that intake, but that 90 deg elbow looks ugly imo. I'll just stick w/ my LS6 until something else better than a FAST comes along that fits under a stock hood and doesn't look ugly
Brandon
Other than sheetmetal stuff like the beck or something custom made, I wouldnt hold your breath.
Brandon
Brandon
Hey man thanks for the advice. I'll be sure and not.....*hold my breath*
Yeah guys I am still thinking of getting the FAST 90MM T/B & Intake. But am hoping to get some good gains. $1200 for 7 to 11 rwhp & rwtq might just be okay...I guess.
Brandon
