4L80E Trans and MS3 cam
Old 04-18-2006, 07:34 AM
Xtremes10's Avatar
Default 4L80E Trans and MS3 cam
I am hoping that this turns out ok, for right now ill be running just a HD 4X4 4L80E trans (transfer case was taken off, only has 5 miles on it) with my MS3 cam, which means, I have to most likely take it around 6800, I was wondering if anyone has tried taking this trans and cam combo to around there without having to do work on the trans and completally rebuilding it?
Old 04-18-2006, 07:54 AM
LS1Tech Sponsor
hellbents10's Avatar
My freind has a 2500hd truck, 4wd ext cab. It has just a shift kit in the 80e. It has a TSp 233/239 595/603 on a 113LSA. It shift out of 1st at 6900, out of 2nd at 6700. It is working really well, this truck is his daily driver. It weighs 6000lbs and runs 96.5mph in the quarter with the stock intake, TB, and exhaust manifolds yet. It also has MTI stage 2e heads.
Old 04-18-2006, 08:00 AM
Xtremes10's Avatar
nice, so it can take the abuse? I wont be hitting it WAY hard off the line either, and if its driven at all on the street, then it will be light, BTW nice Dime you got there, hope mine will run some nice times once im done with this setup for it
Old 04-18-2006, 08:16 AM
LS1Tech Sponsor
Yes it can take the abuse.
Old 04-18-2006, 08:23 AM
Xtremes10's Avatar
great, just what I needed, now to have some fun with it! hah and im so used to it having to shift around 5000 with my 4.3l, so it will be fun taking the motor up so far!
