will this fix y pipe banging?
I can't stand how my y pipe bangs after my lt + ory install. I know poly motor mounts will probably fix the problem, but I don't want to mess with that right now. Will putting some heater hose between the floorboard and the y pipe at the tight spots stop the banging? What could I use to secure the hose to the y pipe? I thought about just duck taping some on there but I'm worried the tape might catch fire and zip ties would probably melt.
I was having the same problem not to long ago. I went to Lowes Hardware and bought some hi-temp heater hose, took my pocket knife and cut it open lengthwise and then get a hose clamp and secured the open rubber hose in between my driver side floorboard and the ORY. No more banging.
I've also heard of people who have used a breaker bar to widen the gap between the floorboard and ORY (when the car is up on the lift).
spl try a bump stop its on the stock y but put n the after market y it dont come with one but that should stop your y pipe from bothering ya.if you have your old y pipe you took off youll see it on the pipe itself its the piece that bolted to the trans you can fab your own or buy one i seen one on the slp website
