Y pipe question
Have you tried contacting someone that sells Jet Hots, or installs them, they would probably know best if it is possible. I wouldn't contact the manufacturer, b/c they will probably say that only their product will work.
As far as I know the SLP lt's hang down the lowest of any lt's so I would venture to say that the jet hot ORY probably won't work w/o some modification. Is there a reason you want to switch y pipes? your sig says you already have the slp one. Just curious
Josh
Josh
